The water temperature is backwards. Warm is hot, cold is hot
My washer will add hot water on cold, hot water on warm, hot water on everything. We have switched the hoses and still hot. We have turned off the hot and selected cold and the washer just hums not filling at all. We have taken to turning off our hot water tank and emptying it of hot water (showers, dish washer, etc.) in order to wash clothes on cold. It has ruined several loads of clothing with hot water!
좋은 질문 입니까?
댓글 3개
Thank you all for your help. I tried all of the options mentioned and the Y is the only thing that worked. I had Sears Repairman (A and E Factory Repair Co.) come out today to fix it. He told me it was the screen clogged. He also changed the thermistor on my dryer. My washer still doesn't work hot and cold properly. I discovered after shrinking/ruining a load when the repairman left telling me it was "perfect now!" $247 later, we are back to the Y in the back! :-(
becky hoban 의
Got hot and cold water, the problem’s hot water comes out of the faucet with the blue shut off handle on the left.
JAV 의
Believe the problem’s the facet’s were put on backwards. Wonder if the colored handle on the faucet comes off
JAV 의
