4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
3267 질문 전체 보기
How to reduce 8+ gigabytes of yellow "other" in the capacity?
It's taking up a precious 8.8 of my 32 gigs. I have tried restoring (from a backup) to no avail. Restoring as a new phone would result in losing years worth of text message history. Please help! Thanks!
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
3개의 답변
선택된 해법
Nathan, the storage capacity is probably at 8.8GB because of the stuff that you have on there for years. If you want to free up the memory, you have to move the stuff of your phone and onto a something more permanent. There is no way to free anything up if you do not move it off the phone. Time for some house cleaning :) Commercial software is available for doing this, like this one or you can try the trial version from here. Hope this helps, good luck
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
If the text messages are important to you, you should consider getting software that can copy them to your computer. After you do that, you can restore as new.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Go to the apps store and buy an app called sms export - downloads all your text msgs. needed my texts as evidence in court and i used it.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Nathan 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 4,197
