Bosch GBA Battery 14.4V 1.5Ah Teardown
도구
해당 기기를 고치는데 사용하는 일반 도구들 입니다. 매 절차에 모든 도구를 사용하지는 않습니다.
Background and Identification
The Bosch GBA Battery is a basic battery that comes as a pair in common cordless drill sets made by Robert Bosch GmbH (also known as Bosch), a German multinational engineering and technology company. Bosch’s operating areas are spread across four business sectors including mobility (hardware and software), consumer goods (including household appliances and power tools), industrial technology (drive and control), and energy and building technology. Bosch’s Power Tools division supplies power tools, power tool accessories, and measuring technology. One of Bosch’s focal points is convenient, high-performance cordless tools that are powered by batteries like the GBA. The GBA battery can be identified by model number 2607336800.
The GBA battery requires one Lithium-ion battery, which is generally included with the battery. The GBA battery is made from 18650 cells with a 10-Amp rating. Bosch advertises that the battery does not suffer from self-discharge or memory effect. The battery is compatible with all tools within its voltage class (14.4 Volts). It is designed to be lightweight so it is suitable for overhead applications.
The Bosch GBA battery is mainly black plastic with some grey details. The name “Bosch” is printed in red capital letters across the front of the battery and on the side in smaller font. Its specifications, ‘14,4V’ and ‘1,5 Ah Li-Ion,’ are printed in white font on the side of the battery.
Technical Specifications
Battery Voltage: 14.4 V
Current Flow Over Time: 1.5 Ah
Weight: 280 g
