Input Shaft Oil Seal
지원 질문
질문하기질문이 없습니다. 가장 먼저 질문을 해 주십시오!
도구
해당 기기를 고치는데 사용하는 일반 도구들 입니다. 매 단계에 모든 도구를 사용하지는 않습니다.
Background and Identification
The Honda Rear Tine Tiller FRC800 is a tiller manufactured by Honda. It employs the Honda GX240 engine for powerful tilling. This tiller has a tilling width of 20 inches with a tilling diameter of 12 inches. It is a self-propelled tiller with key safety features. These safety features include a heavy-duty shield above the rear tines, a mechanism that prevents the tines from going in reverse, and easily accessible controls. Additionally, the tiller has an adjustable tilling depth and a handlebar that can be set to four different possible heights.
This device has a three-year warranty from Honda. A variety of replacement parts are also available.
This tiller has tines located at the rear of the tiller. It has a powerful motor housed in the device’s body, as well as large wheels. There is a long, adjustable handle that extends outward for user operation. The tiller is mostly red and black in color. This tiller is wider than other Honda tillers, and it has tines in the rear, while other tillers have tines in the front.
Specifications
- Dimensions: 65.4 x 24.0 x 49.0 inches
- Weight: 265 pounds
- Tiller Type: rear tine
- Tilling Width: 20 inches
- Tine Diameter: 12 inches
- Engine: Honda GX240
- Fuel Capacity: 4.6 quarts
- Max Tine Speed: 225 RPM
- Transmission Type: chain and gear drive
