1 도표
인기 포럼 질문
질문하기질문이 없습니다. 가장 먼저 질문을 해 주십시오!
모델
XAG01Z
Background
The Makita XAG01Z is a compact 18V LXT Lithium-Ion Cordless 4-1/2" Cut-Off/Angle Grinder, weighing 5 lbs. with battery. This grinder is appropriate for grinding, sanding, and polishing tasks due to its 10,000 RPM motor. The device features a rubberized grip for comfort during use and a slide switch with lock-on for user convenience. The XAG01Z is compatible with Makita 18V Lithium-Ion batteries marked with a Star symbol. The model number can be located on the product label, identified by the SKU: makita-xag01z. Be aware that the XAG01Z has been discontinued and replaced by the XAG03Z model.
Technical Specifications
- Blade Diameter: 4-1/2 Inches
- No Load Speed: 10,000 RPM
- Battery: 18V LXT Lithium-Ion
- Battery Charge Time: 30 Minutes
- Spindle Thread: 5/8" - 11 UNC
- Length: 12-1/2 Inches
Warranty
The Makita XAG01Z comes with a 3-year warranty on the tool. To claim the warranty, you will need to contact the manufacturer or the authorized dealer.
