1 도표
인기 포럼 질문
질문하기질문이 없습니다. 가장 먼저 질문을 해 주십시오!
문서
모델
BGA452
Background
The Makita BGA452 is a cordless angle grinder appropriate for numerous cutting and grinding tasks. The compact design and ergonomic shape contribute to its versatility, making it suitable for professional and DIY applications. The model number, BGA452, is located on the device's nameplate, generally found on the side of the tool. The grinder includes a built-in motor that provides up to 10,000 RPM, a slide switch with lock-on, and a compact barrel grip for handling. The materials used in its construction ensure durability and prolonged performance.
Technical Specifications
- Voltage: 18V
- Battery Type: Lithium-Ion
- No Load Speed: 10,000 RPM
- Wheel Diameter: 4-1/2 inches
- Arbor: 5/8 inch - 11 UNC
- Dimensions (L x W x H): 12-1/2 x 5 x 4 inches
- Net Weight (with battery): 5.3 lbs
