1 도표
인기 포럼 질문
질문하기질문이 없습니다. 가장 먼저 질문을 해 주십시오!
문서
모델
9557NB
Background
The Makita 9557NB is an angle grinder intended for diverse cutting and grinding tasks. Its model number, 9557NB, is visible on the label situated on the side of the device. The angle grinder exhibits a blue and black color scheme with a compact and lightweight design. The 7.5-amp motor delivers output power in a more compact tool, while the small diameter barrel grip contributes to user comfort. The labyrinth construction of the grinder seals and safeguards the motor and bearings from dust and debris, promoting a longer tool life.
Technical Specifications
- Dimensions: 5.1 x 14.6 x 5.3 inches
- Weight: 4.6 lbs
- Material: Metal and plastic
- Color: Blue and black
- Motor: 7.5-amp
- No Load Speed: 11,000 RPM
- Spindle Thread: 5/8-inch x 11 UNC
- Max Wheel Diameter: 4-1/2 inches
