Battery
답변 2개 0점 |
How do I remove the battery? |
답변 2개 0점 |
Why doesn’t the webcam turn on? |
도구
해당 기기를 고치는데 사용하는 일반 도구들 입니다. 매 단계에 모든 도구를 사용하지는 않습니다.
Troubleshooting
If you are having difficulties with theToshiba Satellite L305D-S5900, try referring to the troubleshooting page.
Background and Identification
The Satellite L305D-S5900 is a Toshiba laptop that generally comes standard with Windows Vista Home Premium 32-bit, webcam, ethernet, dial-up & WLAN connection availability, 3GB RAM, 250GB hard disk drive that runs at 5400RPM, and a 15.4” screen. All of which can vary by computer, but uncustomized ones come with this configuration. Since the laptop varies in size, the weight varies as well but is an average of 6 lbs making it slightly more cumbersome than other laptops.
This laptop was released in 2002 and has since been replaced by newer Toshiba Satellite and other model laptops; however, the Satellite series has been discontinued as of 2016.
