Male Air Compressor Adapter Gasket
Popular Forum Questions
질문하기질문이 없습니다. 가장 먼저 질문을 해 주십시오!
도구
해당 기기를 고치는데 사용하는 일반 도구들 입니다. 매 단계에 모든 도구를 사용하지는 않습니다.
Background and Identification
The WEN 18 Gauge 2-Inch Air Brad Nailer is a nailer that can shoot brad nails between ¾ in. and 2 in. It has a blue and yellow aluminum body with a black rubber grip handle. The tool is about 3 pounds in weight total. It is a pneumatic tool, which means it runs on compressed air. Consequently you must have an air compressor that can deliver 60 to 100 PSI to operate the tool. The Air Brad Nailer is equipped with ¼ inch NPT air inlet fitting just below the grip.
