Battery
답변 1개 0점 |
laptop not powering on, no charger light. |
답변 없음 0점 |
после замены диска перестал включаться/after replacing the disc stoppe |
도구
해당 기기를 고치는데 사용하는 일반 도구들 입니다. 매 단계에 모든 도구를 사용하지는 않습니다.
Background
The HP Pavilion 15-cc023cl was released in October 2016. It is ideal for word processing and general use. The HP Pavilion 15-cc023cl comes with the Intel Core i5-7200U microprocessor, 12 GB DDR4-2133 SDRAM standard memory, and Intel HD Graphics 620 (up to 6.06 GB). In addition, it has a 1 TB 5400 rpm SATA hard drive, 3-cell, 41 Wh Li-ion battery, 45 W AC power adapter, and 1 multi-format SD media card reader expansion slot. The display is a 15.6" diagonal HD SVA WLED-backlit touch screen and the keyboard is full size, backlit, and has a numeric keypad. It comes preinstalled with Windows 10 Home 64.
Identification
To identify your device, look for the model and product number on the bottom of the laptop or on the box that it came in.
Technical Specifications
Operating System
Windows 10 Home
Display
15.6-inch diagonal HD WLED-backlit touchscreen with a resolution of 1366x768
Memory
12 GB
Processor
Intel's 7th generation Core i5-72000U (2.5 GHz base frequency, up to 3.1 GHz with Intel® Turbo Boost Technology, 3 MB cache, 2 cores)
Weight
4.49 pounds
