주요 콘텐츠로 건너뛰기
IBM ThinkPad 600E Battery Replacement
  1. IBM ThinkPad 600E Battery Replacement, Battery: 1 단계, 이미지 1/3 IBM ThinkPad 600E Battery Replacement, Battery: 1 단계, 이미지 2/3 IBM ThinkPad 600E Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Flip the laptop over and find the battery latch.
  2. IBM ThinkPad 600E Battery Replacement: 2 단계, 이미지 1/1
    • Move the latch to the side with the unlocked symbol.
  3. IBM ThinkPad 600E Battery Replacement: 3 단계, 이미지 1/3 IBM ThinkPad 600E Battery Replacement: 3 단계, 이미지 2/3 IBM ThinkPad 600E Battery Replacement: 3 단계, 이미지 3/3
    • Pry the battery out using your fingers.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Kevin Nguyen
회원 가입일: 10/04/16
722 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-4, Nance Fall 2016 USF Tampa, Team 1-4, Nance Fall 2016 회원
USFT-NANCE-F16S1G4
4 회원들
안내서 12개 작성하였습니다
댓글 2개
The IBM ThinkPad 600 battery uses six Panasonic Li-Ion cells in a 3Sx2P setup, and has a battery controller onboard the pack (under the lump covered by the IBM label). The problem has been that controller which limits the maximum energy output, especially if the pack is too hot. It has a fuse and a thermistor in between the cells. if the controller sees low voltages , the pack will be “open” yet the cells can still be good.
I have opened a pack manufactured in 1996 and the cells were good, such that I have recharged each cell pair directly. If you still have a ThinkPad 600 and several bad packs, open them carefully with a sharp blade along the plastic clamshell, remove the bottom, turn the pack with the label facing down, get a regulated Li-Ion cell charger, attach it carefully to the ends of each pair straps (the cells are welded together), and charge each pair until they have a minimum of 3.2 VDC each (or let it charge up to 4 VDC). Then tape the clamshell together and plug the pack in.
rayramirez - 답글
I am trying to find a video of how to change CMOS battery on my IBM ThinkPad 600E
Martyn Hunter - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 30
전체 시간: 1,948
