주요 콘텐츠로 건너뛰기
JBL Charge 3 Speaker Replacement
필요한 것
  1. JBL Charge 3 Speaker Replacement, Front Cover: 1 단계, 이미지 1/3 JBL Charge 3 Speaker Replacement, Front Cover: 1 단계, 이미지 2/3 JBL Charge 3 Speaker Replacement, Front Cover: 1 단계, 이미지 3/3
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
  2. JBL Charge 3 Speaker Replacement: 2 단계, 이미지 1/1
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
  3. JBL Charge 3 Speaker Replacement, Speaker: 3 단계, 이미지 1/2 JBL Charge 3 Speaker Replacement, Speaker: 3 단계, 이미지 2/2
    • Remove the eight 10mm Phillips #1 screws from around the two front speakers.
  4. JBL Charge 3 Speaker Replacement: 4 단계, 이미지 1/1
    • Pull gently on one of the speakers so it is outside of the housing. Be careful as it is still attached with the wires to the motherboard.
  5. JBL Charge 3 Speaker Replacement: 5 단계, 이미지 1/3 JBL Charge 3 Speaker Replacement: 5 단계, 이미지 2/3 JBL Charge 3 Speaker Replacement: 5 단계, 이미지 3/3
    • Press the small metal tab on the speaker connector with a Phillips #000 screwdriver and gently pull the connector apart.
  6. JBL Charge 3 Speaker Replacement: 6 단계, 이미지 1/1
    • Repeat the previous step for the second connector.
  7. JBL Charge 3 Speaker Replacement: 7 단계, 이미지 1/2 JBL Charge 3 Speaker Replacement: 7 단계, 이미지 2/2
    • Grab the bundled cable connector that joins the speakers to the motherboard with tweezers. Gently pull the connector free.
  8. JBL Charge 3 Speaker Replacement: 8 단계, 이미지 1/1
    • Now that the second speaker is disconnected from the motherboard, pull the speaker and wires out of the housing.
결론
다른 42명이 해당 안내서를 완성하였습니다.
Aidan Hays
회원 가입일: 10/08/18
3,809 평판
안내서 2개 작성하였습니다
Cal Poly, Team S13-G1, White Fall 2018 Cal Poly, Team S13-G1, White Fall 2018 회원
CPSU-WHITE-F18S13G1
3 회원들
안내서 26개 작성하였습니다
댓글 31개
Where I can buy the same jbl speaker ?
Ekinox - 답글
I need to replace my JBL charge 3 speaker
Lara Esther -
Where can buy the small speakers? Helpp
Luis Cilia - 답글
I have to pull out the motherboard to get those speakers out.
Tr0ll05aur0s 3z - 답글
where can i buy the replacement speakers?
Yhamani Pangarungan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 27
7일 전: 220
30일 전: 943
전체 시간: 87,459
