주요 콘텐츠로 건너뛰기
Mac mini Late 2014 SSD Replacement
필요한 것
  1. Mac mini Late 2014 SSD Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
  2. Mac mini Late 2014 SSD Replacement: 2 단계, 이미지 1/3 Mac mini Late 2014 SSD Replacement: 2 단계, 이미지 2/3 Mac mini Late 2014 SSD Replacement: 2 단계, 이미지 3/3
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
  3. Mac mini Late 2014 SSD Replacement: 3 단계, 이미지 1/2 Mac mini Late 2014 SSD Replacement: 3 단계, 이미지 2/2
    • Lift and remove the bottom cover.
  4. Mac mini Late 2014 SSD Replacement, Antenna Plate: 4 단계, 이미지 1/1
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
  5. Mac mini Late 2014 SSD Replacement: 5 단계, 이미지 1/2 Mac mini Late 2014 SSD Replacement: 5 단계, 이미지 2/2
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. Mac mini Late 2014 SSD Replacement: 6 단계, 이미지 1/1
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
  7. Mac mini Late 2014 SSD Replacement: 7 단계, 이미지 1/2 Mac mini Late 2014 SSD Replacement: 7 단계, 이미지 2/2
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
  8. Mac mini Late 2014 SSD Replacement: 8 단계, 이미지 1/2 Mac mini Late 2014 SSD Replacement: 8 단계, 이미지 2/2
    • Carefully pull the antenna cable out from the gap between the power supply and case.
  9. Mac mini Late 2014 SSD Replacement: 9 단계, 이미지 1/1
    • Remove the antenna plate from the Mac mini.
  10. Mac mini Late 2014 SSD Replacement, SSD: 10 단계, 이미지 1/1
    • Remove the 5 mm T5 screw securing the SSD.
  11. Mac mini Late 2014 SSD Replacement: 11 단계, 이미지 1/3 Mac mini Late 2014 SSD Replacement: 11 단계, 이미지 2/3 Mac mini Late 2014 SSD Replacement: 11 단계, 이미지 3/3
    • Lift the free end of the SSD up slightly and pull it out of its socket.
  12. Mac mini Late 2014 SSD Replacement: 12 단계, 이미지 1/3 Mac mini Late 2014 SSD Replacement: 12 단계, 이미지 2/3 Mac mini Late 2014 SSD Replacement: 12 단계, 이미지 3/3
    • Carefully lift the SSD out of the case without scratching or touching the gold contacts.
결론
다른 104명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
465,777 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 29개
If I have a Mac Mini without SSD, only with normal Hard Drive (NO Fusion). Can I install a new one SSD like on this tutorial?. Thanks!
Juan Miguel Ramirez - 답글
Please see my comment later in the thread.
Thomas Hall -
Si, yo lo hice y la diferencia es abismal. Necesitaras un adaptador y por supuesto el SSD. Yes, I did it and the difference is abysmal. You will need an adapter and of course the SSD.
Manuel Jesús Flores Jiménez -
Yes, but you need to add a cable to connect it. If you buy the SSD from OWC, they sell a kit which includes the cable and tools (for an extra $20-40, depending on what size/model SSD you get).
shamino -
I have the same question as Juan
Cronan McNamara - 답글
댓글 쓰기
조회 통계:
24 시간 전: 36
7일 전: 187
30일 전: 861
전체 시간: 175,055
