필요한 것
使用一个吸盘将屏幕拉出缝隙,在缝隙内插入拆机片,注意,拆机片不能划太深,否则会将指纹排线割断。
将拆机片沿手机四周划开,拔吸盘(稍用力,要慢慢来),吸起后盖。
把后盖向右翻开,一定得小心,翻开角度太大可能会扯断排线。
要重新组装你的设备,请按逆序操作。
要重新组装你的设备,请按逆序操作。
다른 37명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 22개
Can the antenna cable (black thin one) be reused?
hi, when you replace a faulty battery does the screen needs to be changed as well even though the screen is fine?
Normally if you can remove the battery, without damaging the screen then just replacing the battery should be ok
Harvey -
I had to replace the back cover as well as it was also damaged. You will have to try it and see if the adhesive is still strong enough to stick.
Harvey -
