주요 콘텐츠로 건너뛰기
Samsung Galaxy A5 Display Replacement
필요한 것
  1. Samsung Galaxy A5 Display Replacement, Display: 1 단계, 이미지 1/3 Samsung Galaxy A5 Display Replacement, Display: 1 단계, 이미지 2/3 Samsung Galaxy A5 Display Replacement, Display: 1 단계, 이미지 3/3
    • Switch off your phone.
    • If your screen is cracked you want to cover the front panel with tape to protect yourself from glass shards and get a better grip to lift it.
    • Use an iOpener to soften the glue on the edge of the display. Concentrate on the sides first and then on the bottom part.
    • With an iSclack or a suction handle you can lift the display a little bit to get in the gap with an opening pick.
    • The phone screen is composed of two layers (glass and display). Ensure that you are removing both layers and not splitting the two layers.
    • In the beginning just insert the tip of the opening pick and slide along the side to loosen the glue. Leave the top and bottom alone for now.
  2. Samsung Galaxy A5 Display Replacement: 2 단계, 이미지 1/3 Samsung Galaxy A5 Display Replacement: 2 단계, 이미지 2/3 Samsung Galaxy A5 Display Replacement: 2 단계, 이미지 3/3
    • When the glue is loosened enough on the side you can lift the display a little bit more to get underneath the display with an opening pick.
    • Take a second opening pick and work your way around the bottom edge.
    • The software buttons in the lower left and right corners of the screen have ribbon cables that are glued to the display. Be very careful that your pick cuts between the screen and buttons and does not cut these wires.
    • Repeat the last step and this one on the other side.
  3. Samsung Galaxy A5 Display Replacement: 3 단계, 이미지 1/3 Samsung Galaxy A5 Display Replacement: 3 단계, 이미지 2/3 Samsung Galaxy A5 Display Replacement: 3 단계, 이미지 3/3
    • Grab the iOpener once again to heat up the bottom and top part to further soften the glue.
    • Now you will be able to move the picks at the bottom closer to the home button and eventually open the display towards the top.
    • Don't open the display all the way. It is still connected to the motherboard.
    • The home button may stick to the display assembly or remain on the midframe. Keep an eye on it if your new display does not come with one already attached.
  4. Samsung Galaxy A5 Display Replacement: 4 단계, 이미지 1/3 Samsung Galaxy A5 Display Replacement: 4 단계, 이미지 2/3 Samsung Galaxy A5 Display Replacement: 4 단계, 이미지 3/3
    • In the top right corner you can find the connector of the display. Use a spudger to unplug it.
    • Now you can remove the display.
결론
다른 70명이 해당 안내서를 완성하였습니다.
Tobias Isakeit
회원 가입일: 03/31/14
116,710 평판
안내서 188개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,506개 작성하였습니다
댓글 9개
Is this guide applicable to all A5 Models?
CLETUS NZE - 답글
This guide is for the 2015 version. For other version see Samsung Galaxy A
Tobias Isakeit -
plz plz plz tell me i have a screen of a5 2015 can i fix it on a5 2017 or 2018 outer look is same on both . can i?
pradeep kumar - 답글
Probably not. They’re completely different. You should also ask that at the 2017 guide as well
Devnol -
Unfortunately, the display are not compatible between the different models.
Tobias Isakeit -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 63
전체 시간: 65,069
