소개
이 안내서를 따라 iPhone 6s Pentalobe/펜타로브/별나사를 풀거나 교체하세요.
필요한 것
분해를 시작하기 전에 iPhone 전원을 끄세요.
iPhone 하단 가장자리 Lightning 커넥터 옆에 위치한 3.4mm P2 Pentalobe/펜타로브/별나사 두 개를 풀어주세요.
기기를 다시 조립하려면 이 지침을 역순으로 따르세요.
다른 39명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 2개
I noticed both my pentalobe screws wouldn’t screw in last time. Upon checking the little components that the screws fix into were loose inside. Not a major drama but they also seem to hold the charger cable in place… or at least I’ve noticed cables are loose on my iPhone 6 since then. Is there a part I can buy to fix this issue, does anyone know please?
I have an iPhone 6s plus, but I got a new phone recently so I put my 6s plus in my side table and went back to it a couple of weeks later just to see that the pentalobe screws are missing and the phone will no longer charge, I also realized that when I plug the charger in its a bit loose. There was also nothing wrong with the phone before it worked perfectly fine.
