我们的竞争者诞生于一个神秘的地方,旭日之国(日本) 。
任天堂红白机,1983年在亚洲大部分地区发售,是NES的海外兄弟。
技术规格
日立2A03 8-bit 1.79 MHz 处理器(基于MOS工艺6502 8位处理核心)
2KB (16Kb) 板载内存
2KB (16Kb) 板载显存
256 x 240像素分辨率
拧开在底部的6个十字螺丝打开底板。
像之前的RCA Studio II主机一样,小霸王非常容易拆解。
you need the hammer of Thor, my son.
What size are the screws?
Perhaps it's worthwhile to mention that the big metal box is known as an "RF Modulator", which converts the more typical video & audio ("baseband") signals into a combined signal at a broadcast ("radio") frequency so that it can be fed to the antenna input of a TV, since hardly any TVs prior to about 1990 had AV inputs.
Lead solder is the best.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 6개
Wow, and I thought my SNES had yellowing issues.
I don’t know why they yellow like they do, but the famicom YELLOWS.
While extremely late, the yellowing is due to the fire retardant that they mixed with the ABS plastic of the shell. Bromine undergoes a chemical reaction when exposed to UV light that essentially breaks it down, resulting in the yellowing color. There is a (temporary) way to undo the changes by using a chemical solution colloquially dubbed “Retr0Bright” in conjunction with UV light to make the plastic look brand new.
Hi : which is the voltage of this device, because it burns mine yesterday :(
If you use a Genesis Model I AC Adapter it should work so, the voltage might be around 9V to 10V.
For future reference
Output: 10VDC 850mA
Conector: Outer Diameter 5.5mm; Inner Diameter 2.1mm
Polarity: Centre Pin Negative
(+)------------(o------------(-)
So, yes, a Genesis AC adapter works just fine (identical connector, and almost similar output), but I don't recomend using a Famicom on the Genesis/MD, the mA output is too low (Genesis needs 1200 mA)
zclaudio -
