소개
2011年10月4日。让我们来谈谈iPhone。昨天的新闻稿 给我们带来了一些关于即将到来的iPhone 4S的新消息(回顾10月14日拆解)以及下一代iPod Nano。 当我们等待今年打电话给“水果”时,我们接到了iPod Nano产品线的最新补充。
“有趣的事实”:这个新发布的Nano并不比上一个iPod Nano更酷。 事实上,他们是完全一样的。 看看下面为什么。
在Twitter上关注iFixit获取最新更新。
필요한 것
我们最喜欢的苹果“纳米切片”回来了,并有一些有趣的功能被包装在里面。
1.54寸多点触控显示屏
240 x 240像素分辨率
内置加速度计
改进了Nike+的兼容性
可充电锂离子电池,可支持长达24小时的音乐播放
8 GB或16 GB内部存储
到前面,到后面,到前面,到后面。 我都要打瞌睡了...
就像去年一样,1.54“液晶屏幕配备了多点触控,我们仍然感到困惑,为什么你需要两个手指来操作这个设备。
显示器仍然是240x240像素的显示器,并且与前玻璃粘合在一起。
Multi-touch is necessary to rotate the display. You can select any of the four possible orientations with a two-finger twist.
第六代Pod Nano(2011)可维修性得分:5分(10分最容易修复)
好:一旦显示屏被拆下,其余的拆卸就比较简单。
好:带状电缆连接器可以方便地将显示屏和耳机插孔从逻辑板上断开。
中:耳机插孔和音量按钮连接到同一条带状电缆,必须同时更换。
坏:将显示屏从设备上取下需要使用热风枪,因为有很多粘合剂。
坏:将电池焊接到逻辑板上,使更换单个组件更麻烦。
Interesting, but this is NOT a "7th generation" model, its still the 6th generation - officially! Looked at your iPod touch "5th generation" page - yup, its still 4th gen!
rowanlloyd - 답글
다음 번역가들에게 특별히 감사 드립니다:
100%
Charles Wang님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 2개
After opening the iPod Nano 6th gen and trying to fix the power-button issue (a very common problem, seen all the YouTube movies about it) I have put together the device. Unfortunately it won't power up anymore, at least the screen is not working or the device is not recharging anymore. Either way, be careful, after disassembling this device might not work anymore. Delicate parts are in place. Good luck with the teardowns.
Hi Bas Flipsen!
Please bear in mind that this is a teardown, not a repair guide, we have actual step-by-step guides for this device on the device page. For a button replacement, you can follow the headphone jack assembly guide!
