이 번역은 기계에 의해 생성된 것이며, 아직 사람이 검토하지 않았습니다. 이 언어를 아세요? 리뷰 보기.
소개
엔진 문제 진단 방법입니다.
필요한 것
동영상 지침
결승점
다른 12명이 해당 안내서를 완성하였습니다.
엔진 문제 진단 방법입니다.
지난 24시간: 3
지난 7일: 41
지난 30일: 263
전체 시간: 8,145
9가이드 댓글
Question,, I have a 1999. Ford F150 4x4 5.4 engine. Was making a clanking noise last night I was going down road and it shut off. I thought it jumped timing, but this dude told me to check the torque converter. Could this be true, or the bad news that it is my engine. Please help. Thank You. Reply to: Sahutto122666@gmail.cim
Sherry Annette Horton Hutto - 답글 공유
Feeling desparate can torque converter cause problems associated with the engine?
I doubt that it's a torque converter, without hearing it I'd have no idea what's going on , Id have a repatable technician take a look at it
Tim - 답글 공유
Bought an old Suzuki Ute Trayback to use around the farm. Previous owner’ s children drove it 5 km morning and afternoon to catch school bus. It has some mods like an electric fuel pump on an extra large fuel tank probably part of the conversion to a trayback.
it starts ok, lots of choke, will idle for twenty minutes, no probs, but when I drive it around it starts to run rough after ten minutes or so. Gradually it loses power, seems to be running on three cylinders then stops and won't restart until it cools right down about half an hour later. No sign of overheating on gauge, has oil and water.
would you suggest fuel or ignition probs?
Brian Ede - 답글 공유
Torque Converters are a transmission problem
Wolfman - 답글 공유
