주요 콘텐츠로 건너뛰기
(Fat) Xbox 360 Hard Drive Replacement
필요한 것
  1. (Fat) Xbox 360 Hard Drive Replacement, Remove the bottom screws: 1 단계, 이미지 1/3 (Fat) Xbox 360 Hard Drive Replacement, Remove the bottom screws: 1 단계, 이미지 2/3 (Fat) Xbox 360 Hard Drive Replacement, Remove the bottom screws: 1 단계, 이미지 3/3
    • Buy the drive at a cost you can afford to eat. This will void any warranties offered.
    • Remove the 3 screws from the bottom of the drive. Use a T6 Torx driver.
    • Remove the warranty seal and final screw. Use a T6 Torx driver.
  2. (Fat) Xbox 360 Hard Drive Replacement, Disassembly tip: 2 단계, 이미지 1/1
    • If the drive is difficult to open and you are opening it to put the drive into a later Xbox 360 with no intention to preserve the enclosure, a screwdriver or pry tool can help.
    • If you are opening it to replace the drive inside for an original console, it is best to use a plastic pry tool instead. While a screwdriver "works" it will likely mar the enclosure.
  3. (Fat) Xbox 360 Hard Drive Replacement, Open the drive: 3 단계, 이미지 1/3 (Fat) Xbox 360 Hard Drive Replacement, Open the drive: 3 단계, 이미지 2/3 (Fat) Xbox 360 Hard Drive Replacement, Open the drive: 3 단계, 이미지 3/3
    • If you are taking the enclosure apart for the bare drive, less caution is needed.
    • After removing the 4 bottom screws, remove the top cover. Remove the spring and locking tab before removing the drive cage.
    • Remove the drive cage from the drive enclosure. If the drive has never been opened, additonal force may be required.
  4. (Fat) Xbox 360 Hard Drive Replacement, Disconnect and remove the hard drive: 4 단계, 이미지 1/3 (Fat) Xbox 360 Hard Drive Replacement, Disconnect and remove the hard drive: 4 단계, 이미지 2/3 (Fat) Xbox 360 Hard Drive Replacement, Disconnect and remove the hard drive: 4 단계, 이미지 3/3
    • Remove the four T10 Torx screws securing the hard drive.
    • After removing the screws, slide the top cover off and disconnect the drive.
    • Disconnect the hard drive and remove it from the enclosure.
결승점
다른 9명이 해당 안내서를 완성하였습니다.
Nick
회원 가입일: 11/10/09
88,752 평판
안내서 49개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,521개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 32
30일 전: 215
전체 시간: 9,155
