주요 콘텐츠로 건너뛰기
Removing factory feet from a Mac Laptop (Non-Retina)
필요한 것
  1. Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: 1 단계, 이미지 1/2 Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: 1 단계, 이미지 2/2
    • I am using a 2011 13" MacBook Pro. Most machines are similar, but variations may exist.
    • If possible, disconnect the battery to protect your components once the bottom is removed.
    • Remove the bottom cover of your MacBook with the guide for your specific system.
  2. Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: 2 단계, 이미지 1/3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: 2 단계, 이미지 2/3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: 2 단계, 이미지 3/3
    • Before removing the good feet, remove the failed feet first. These may come off without disassembly if they have fully failed.
    • After removing the damaged feet, remove the intact feet. Follow the disassembly guide for your specific Mac.
  3. Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: 3 단계, 이미지 1/3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: 3 단계, 이미지 2/3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    iFixit Opening Picks (Set of 6)
    구매
    • To remove the intact feet, score the internal plug. Once scored, remove the plug with a guitar pick.
    • After removing the inner plug, push the foot out with a spudger or screwdriver.
  4. Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: 4 단계, 이미지 1/2 Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Adhesive Cleanup Kit (Set of 12)
    구매
    • If the adhesive ring remains, remove it first. Clean the chassis with denatured alcohol or adhesive cleaner.
    • After removing the old feet, install the new set onto the bottom cover.
    • Re-install the cover on the computer.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
Nick
회원 가입일: 11/10/09
88,851 평판
안내서 49개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,528개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 16
30일 전: 51
전체 시간: 4,359
