소개
The screen is one of the most important parts of the device, and breaking it may mean the end of its use. Due to the device's age, finding a new screen may be difficult, but if found, replacing it for the old one is straightforward.
필요한 것
Using a Philips #0 or #00 screwdriver, locate and unscrew the four screws holding the back cover on the device.
이 단계에 사용된 도구:Tweezers$4.99
Locate the brown serial connector on the left side of the device. Using the flat head screw driver, push the little tabs (one on each side) out towards you as pictured.
They should extend about 1/16 of an inch (1.5 mm).
Now take the screwdriver/tweezers and gently pry out the serial tab as shown .
Use the ipod opening tool to pry the cover from the internal plastic frame; the internal frame and screen will come off at the same time.
Place the front cover aside.
