주요 콘텐츠로 건너뛰기
1 - Kettle - The different functions
  1. 1 - Kettle - The different functions, What are the functions of a kettle?: 1 단계, 이미지 2개 중 1개 1 - Kettle - The different functions, What are the functions of a kettle?: 1 단계, 이미지 2개 중 2개
    • The kettle is a kitchen utensil used to bring a liquid to a boil. Electric kettles, which are the subject of this study, have a built-in heater.
    • The most common models are the cordless kettles: the kettles are placed on a base (see photo) connected to an electrical outlet, during the heating phase. The container can then be detached from the base and used as an ordinary container.
    • The operation of the electric kettle is based on the Joule effect. The kettles are equipped with a heating resistor in the form of a ring-shaped tube. The current, when it passes through the resistor, causes an increase in the thermal energy of the ring: the water is heated by heat transfer.
    • To learn more about the Joule effect, visit this site. See also the definition of a "kettle" on Wikipedia
  2. 1 - Kettle - The different functions, Description: 2 단계, 이미지 3개 중 1개 1 - Kettle - The different functions, Description: 2 단계, 이미지 3개 중 2개 1 - Kettle - The different functions, Description: 2 단계, 이미지 3개 중 3개
    • Our study is of the Moulinex brand model AC10-10S011. It is 1100W.
    • The device consists of a base 1 and a container 2. The base is equipped with a power cord. It is equipped with a device 3 which ensures the electrical continuity with the heating resistor which is in the container. This device is secured to avoid any contact with the electrical conductors.
    • In the tank is a heating element 4. A switch allows to start and stop the heating. This kettle is also equipped with an automatic stop when the water has reached the right temperature.
결론
We now know what a kettle is and what its different functions are. We can move on to the study of its operation in the following guide: "a kettle, how does it work?"“Kettles, how do they work?”
다른 9명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
shingle님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Atelier Soudé
회원 가입일: 12/13/18
4,642 평판
안내서 18개를 작성함
Atelier Soudé Atelier Soudé 회원
Local Repair Groups
5 회원들
안내서 43개를 작성함
1가이드 댓글
Hi evry bary 'i m for algeria and i want working whith you so if you ar iteressed send me a messaga message please
Belmokdad Idir - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 66
전체 시간: 5,057
