주요 콘텐츠로 건너뛰기
100% Fix Non-Genuine Battery Warning / Important Battery Message On iPhone XS And Above
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
동영상 개요
  1. 100% Fix Non-Genuine Battery Warning / Important Battery Message On iPhone XS And Above, Why the important battery message appears: 1 단계, 이미지 1/1
    • Why the message appears after battery replacement?
    • Chips used in batteries of iPhone XS and above feature an authentication module which stores information that can be used to pair the battery cell with the phone’s logic board.
    • To remove the Important Battery Message, we can transplant the battery management system of the original battery to the replacement battery.
  2. 100% Fix Non-Genuine Battery Warning / Important Battery Message On iPhone XS And Above, Remove Original BMS: 2 단계, 이미지 1/1
    • Here we will use a new iPhone XS battery cell.
    • Tear off the insulation tape on the original battery management system. Then remove the protective cover. Remove the battery management system with Cutting Nipper afterwards.
    • Be careful during your operation. Do not tear the battery flex cable or damage the battery management system.
  3. 100% Fix Non-Genuine Battery Warning / Important Battery Message On iPhone XS And Above, Weld Original BMS: 3 단계, 이미지 1/1
    • Now we need to weld the original BMS onto the new battery cell.
    • Cut off a part of the nickel sheet on the new battery cell. Then place the BMS in the right position. Do not confuse the anode with the cathode.
    • Continue to weld the BMS with the welding machine. Once done, apply the protective cover and insulation tape.
  4. 100% Fix Non-Genuine Battery Warning / Important Battery Message On iPhone XS And Above, Test: 4 단계, 이미지 1/1
    • Activate the battery with the activation board. Then get the battery installed.
    • Connect the screen and then the battery. Power on and test. There is no important battery message this time.
결승점
다른 5명이 해당 안내서를 완성하였습니다.
Phryne
회원 가입일: 11/17/19
20,386 평판
안내서 18개 작성하였습니다
댓글 14개
Thanks for sharing! What device can be used for welding the parts? I don’t want to damage the cells of the battery in this proces?
Also will the new battery will be displayed as 100% in the settings menu?
halders - 답글
You need a welding machine as shown in the video to finish the job. And you will get the same battery health as before.
HAKU_LYU -
No need for a welding machine according to this youtube vid (see around 2 mins in). Just a cheap soldering iron can be used.
ieffedit -
Now you gave ideas to apple to make the BMS module like the one from laptops: once you disconnected the cell it will require re-programming (which is not possible because of a security key) :)
Florin Neagu - 답글
Instead of welding, would silver conductive glue work to attach the BMS to the new battery?
duff - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 29
전체 시간: 41,587
