주요 콘텐츠로 건너뛰기
12-String Takamine G Series Guitar String Replacement
필요한 것
  1. 12-String Takamine G Series Guitar String Replacement, Guitar String: 1 단계, 이미지 1/3 12-String Takamine G Series Guitar String Replacement, Guitar String: 1 단계, 이미지 2/3 12-String Takamine G Series Guitar String Replacement, Guitar String: 1 단계, 이미지 3/3
    • Turn the tuning peg corresponding to the string you want to change clockwise until the string is completely loose.
    • This is only if the string is damaged but not completely broken (if the string is completely broken skip to step 2).
  2. 12-String Takamine G Series Guitar String Replacement: 2 단계, 이미지 1/2 12-String Takamine G Series Guitar String Replacement: 2 단계, 이미지 2/2
    • Use wire cutters to take out the pins located on the bridge of the guitar and completely release the string from the guitar.
  3. 12-String Takamine G Series Guitar String Replacement: 3 단계, 이미지 1/2 12-String Takamine G Series Guitar String Replacement: 3 단계, 이미지 2/2
    • Place the new string into the hole in the bridge where the pin was taken out.
  4. 12-String Takamine G Series Guitar String Replacement: 4 단계, 이미지 1/3 12-String Takamine G Series Guitar String Replacement: 4 단계, 이미지 2/3 12-String Takamine G Series Guitar String Replacement: 4 단계, 이미지 3/3
    • Place the pin back into the hole to secure the string.
  5. 12-String Takamine G Series Guitar String Replacement: 5 단계, 이미지 1/1
    • Grab the string and put it through the hole located on the tuning post of the guitar.
  6. 12-String Takamine G Series Guitar String Replacement: 6 단계, 이미지 1/3 12-String Takamine G Series Guitar String Replacement: 6 단계, 이미지 2/3 12-String Takamine G Series Guitar String Replacement: 6 단계, 이미지 3/3
    • Take the string and wrap it around and underneath itself.
    • Pull the string taught.
    • Twist the string over itself and than cut off the excess string.
  7. 12-String Takamine G Series Guitar String Replacement: 7 단계, 이미지 1/2 12-String Takamine G Series Guitar String Replacement: 7 단계, 이미지 2/2
    • Turn the tuning peg counterclockwise to tighten the string.
결론
Rey Navarro
회원 가입일: 09/27/23
145 평판
안내서 1개 작성함
University of Arizona, Team 6-34, Cools Stephens Fall 2023 University of Arizona, Team 6-34, Cools Stephens Fall 2023 회원
ARIZONA-COOLS STEPHENS-F23S6G34
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 65
