주요 콘텐츠로 건너뛰기
1922 GE AOU Fan Power cord Replacement
필요한 것
  1. 1922 GE AOU Fan Power cord Replacement, Power cord: 1 단계, 이미지 1/2 1922 GE AOU Fan Power cord Replacement, Power cord: 1 단계, 이미지 2/2
    • Tip the fan to its side and remove the three size 8 screws using a 9/32 flat-head screwdriver.
    • The screws may be brittle from age, so be careful.
    • Take the bottom plate off the fan and set it aside.
  2. 1922 GE AOU Fan Power cord Replacement: 2 단계, 이미지 1/1
    • Remove the three number 8 screws that hold the switch in place.
  3. 1922 GE AOU Fan Power cord Replacement: 3 단계, 이미지 1/1
    • Remove the switch, carefully sliding the speed lever out of its slot.
    • Don't remove the switch too quickly or you can damage the head-wire.
  4. 1922 GE AOU Fan Power cord Replacement: 4 단계, 이미지 1/1
    • Once the switch is free, unscrew the two knurled nuts holding the wires in place.
  5. 1922 GE AOU Fan Power cord Replacement: 5 단계, 이미지 1/1
    • Turn the switch over and unscrew the nut securing the wire with the 5/16 crescent wrench.
  6. 1922 GE AOU Fan Power cord Replacement: 6 단계, 이미지 1/1
    • Remove the switch and set it aside, then pull the wire through the grommet.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Elias Dorna
회원 가입일: 06/08/16
125 평판
안내서 1개 작성함
Texas Tech, Team 3-5, Rauch SU 2016 Texas Tech, Team 3-5, Rauch SU 2016 회원
TTU-RAUCH-SU16S3G5
2 회원들
안내서 1개 작성하였습니다
댓글 한 개
Westinghouse table fan needs new cord (just bought). 18 gauge cord? Where to buy?
carol w - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 2,741
