주요 콘텐츠로 건너뛰기
1965-1969 Chevrolet Corvair valve adjustment
필요한 것
  1. 1965-1969 Chevrolet Corvair valve adjustment, 1965-1969 Chevrolet Corvair valve adjustment: 1 단계, 이미지 1/1
    • Adjusting the valves first requires removing the valve cover. There are two valve covers, one on each side of the car. In this guide we'll be adjusting the valves on the drivers side, which does not have the exhaust in the way.
    • Look under the back of the car, and on the side of the engine you will see the valve cover.
  2. 1965-1969 Chevrolet Corvair valve adjustment: 2 단계, 이미지 1/1
    • In order to remove the valve cover, locate the 4 bolts which hold it in place and remove them using a 7/16" socket or wrench.
    • Remove them carefully to avoid stripping the holes.
  3. 1965-1969 Chevrolet Corvair valve adjustment: 3 단계, 이미지 1/2 1965-1969 Chevrolet Corvair valve adjustment: 3 단계, 이미지 2/2
    • Next, remove the valve cover and the gasket by pulling out gently.
    • Put a piece of cardboard below to capture the oil which will spill out.
  4. 1965-1969 Chevrolet Corvair valve adjustment: 4 단계, 이미지 1/2 1965-1969 Chevrolet Corvair valve adjustment: 4 단계, 이미지 2/2
    • Now you must attach the 1/3 Valve Cover, which is essentially 1/3 of a valve cover that keeps the oil in while exposing the valves so you can adjust them when the engine is running.
    • Place the valve cover on the lower side of the valves and line up the bolt holes. Verify the gasket is in place and use the bolts you previously removed to attach the adjustment cover.
  5. 1965-1969 Chevrolet Corvair valve adjustment: 5 단계, 이미지 1/1
    • Finally, turn on the engine and you are ready to adjust.
    • Start on the left side and adjust each one at a time using a 5/16" socket.
    • Loosen the bolt on the lifter till you hear that lifter start ticking. The ticking noise should be quite apparent.
    • Then slowly tighten it till it stops ticking. And then tighten in one half turn. Now you can move on to the next valve.
결론
To reassemble, simply follow steps 1-4 in reverse order. Make sure to adjust the valves on the other side of your engine using the same procedure.
Noah
회원 가입일: 10/03/12
574 평판
안내서 4개 작성하였습니다
Cal Poly, Team 6-33, Regan Fall 2012 Cal Poly, Team 6-33, Regan Fall 2012 회원
CPSU-REGAN-F12S6G33
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
Be sure to check and adjust the engine oil level afterward.
To avoid smoke and odor, remove as much spilled oil as possible from the exhaust manifolds.
George - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 5,907
