소개
Being one one of the most important component of a motorcycle, the carburetor is responsible for controlling how much fuel and oxygen is allowed into the engine, and therefore must be kept clean and maintained at all times.
The most common issues that may be due to a poor carburetor are when the engine is in too high or too low RPM when the motorcycle is at idle. Additionally, a poor carburetor can lead too having throttling issues, when you open the throttle nothing happens, or vise versa.
If you are having any of the listed issues, this guide will help disassemble the carburetor in order to clean or fix anything within the part.
필요한 것
The Carburetor is located to the rear of the engine block, right under the gas tank.
다른 2명이 해당 안내서를 완성하였습니다.
