주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
  1. Firstly Disconnect  battery Always take the negative terminal off first.
    • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
  2. Unlatch the two clasps, as outlined in the image. Loosen the screw on the metal band, using a flathead screwdriver.
    • Unlatch the two clasps, as outlined in the image.
    • Loosen the screw on the metal band, using a flathead screwdriver.
  3. Disconnect the electronic sensor from the MAF. Press on the 2 latches, pulling the cable away from the sensor.
    • Disconnect the electronic sensor from the MAF.
    • Press on the 2 latches, pulling the cable away from the sensor.
  4. Disconnect the rubber hose from the MAF. Remove the MAF from the air filter housing.
    • Disconnect the rubber hose from the MAF.
    • Remove the MAF from the air filter housing.
  5. Steps 4-6 are for cleaning only.
    • Steps 4-6 are for cleaning only.
    • Spray the MAF cleaner along the direction of travel, shown by the arrow on top of the sensor.
    • (Mass Air Flow sensor Cleaner)
  6. Clean the electronic coupling with an electronics cleaner. Clean the electronic coupling with an electronics cleaner.
    • Clean the electronic coupling with an electronics cleaner.
  7. Inject conducting lubricant into  the MAF sensor electronic coupling. Inject conducting lubricant into  the MAF sensor electronic coupling.
    • Inject conducting lubricant into the MAF sensor electronic coupling.
  8. Reattach the MAF to the air filter housing and the intake hose. Tighten the screw on the metal band. Latch the clasps on either side of the MAF.
    • Reattach the MAF to the air filter housing and the intake hose.
    • Tighten the screw on the metal band.
    • Latch the clasps on either side of the MAF.
  9. Reattach the electronic cable to the MAF.
    • Reattach the electronic cable to the MAF.
결론
Isaac Nitschke
회원 가입일: 2010년 10월 11일
67 평판
안내서 5개 작성하였습니다
Cal Poly, Team 3-28, Regan Fall 2010 Cal Poly, Team 3-28, Regan Fall 2010 회원
CPSU-REGAN-F10S3G28
4 회원들
안내서 9개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 20
전체 시간: 8,591
