필요한 것
Lift the bottom of the shift boot to expose the shifting socket.
Use snap ring pliers to remove the circlip securing the shifter to its socket.
Remove the bolts securing the transmission to the engine and to the starter.
Generally, a jack is recommended for this.
Remove the four bolts securing the transmission support to the chassis.
Lower the transmission out of the car.
In many instances, the transmission may not come free from the engine once the bolts are removed. If this is the case, a pry bar is recommended to help separate the two.
Remove the 6 allen bolts securing the pressure plate to the flywheel.
Remove the pressure plate.
다른 한 분이 해당 안내서를 완성하였습니다.
