주요 콘텐츠로 건너뛰기
1986-1993 Volvo 240 Distributor Cap Replacement
필요한 것
  1. 1986-1993 Volvo 240 Distributor Cap Replacement, Distributor Cap: 1 단계, 이미지 1/2 1986-1993 Volvo 240 Distributor Cap Replacement, Distributor Cap: 1 단계, 이미지 2/2
    • The distributor cap is located next to the engine and has all of the spark plug wires connecting to it.
    • Pull straight up on the ignition coil wire in the center of the distributor cap to disconnect it.
  2. 1986-1993 Volvo 240 Distributor Cap Replacement: 2 단계, 이미지 1/3 1986-1993 Volvo 240 Distributor Cap Replacement: 2 단계, 이미지 2/3 1986-1993 Volvo 240 Distributor Cap Replacement: 2 단계, 이미지 3/3
    • Connect the spark plug wires to the new distributor cap one at a time. Mixing up the order will result in the engine not firing properly or at all.
    • Pull straight up on the boot of the first spark plug wire to disconnect it from the distributor cap.
    • Be sure to pull on the boot and not the wire itself. Spark plug wires are quite fragile and may break easily.
  3. 1986-1993 Volvo 240 Distributor Cap Replacement: 3 단계, 이미지 1/3 1986-1993 Volvo 240 Distributor Cap Replacement: 3 단계, 이미지 2/3 1986-1993 Volvo 240 Distributor Cap Replacement: 3 단계, 이미지 3/3
    • Install the spark plug wire onto the new distributor cap and make sure it is seated properly.
    • Continue to transfer each spark plug wire to the new distributor cap, maintaining the same arrangement of wires on the cap.
    • Once all of the spark plug wires have been installed on the new distributor cap, set the cap aside.
  4. 1986-1993 Volvo 240 Distributor Cap Replacement: 4 단계, 이미지 1/2 1986-1993 Volvo 240 Distributor Cap Replacement: 4 단계, 이미지 2/2
    • Use a flathead screwdriver to release the clip securing the distributor cap.
    • Only one side of the distributor cap has a spot for the clip to rest. The new cap must be installed in the same orientation.
    • Remove the old distributor cap.
    • When installing the new distributor cap, don't forget to reconnect the center ignition coil wire.
결론
다른 2명이 해당 안내서를 완성하였습니다.
David Hodson
회원 가입일: 04/13/10
150,997 평판
안내서 127개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 25
전체 시간: 6,651
