주요 콘텐츠로 건너뛰기
1986-1993 Volvo 240 Front Brake Rotors Replacement
필요한 것
  1. 1986-1993 Volvo 240 Front Brake Rotors Replacement, Front Wheels: 1 단계, 이미지 1/3 1986-1993 Volvo 240 Front Brake Rotors Replacement, Front Wheels: 1 단계, 이미지 2/3 1986-1993 Volvo 240 Front Brake Rotors Replacement, Front Wheels: 1 단계, 이미지 3/3
    • Jack up the front of the car and place it on jack stands.
    • Never work on or underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or even death.
    • Use an impact wrench or lug wrench to remove the five 19 mm lug nuts from the front wheel.
    • The wheel lug nuts should be torqued to 85 ft-lbs when the wheels are put back on the car.
    • Pull the front wheel off the wheel lugs and set it aside.
  2. 1986-1993 Volvo 240 Front Brake Rotors Replacement, Front Brake Calipers: 2 단계, 이미지 1/2 1986-1993 Volvo 240 Front Brake Rotors Replacement, Front Brake Calipers: 2 단계, 이미지 2/2
    • Use a 15 mm box end wrench to remove the two bolts on the back of the brake caliper.
  3. 1986-1993 Volvo 240 Front Brake Rotors Replacement: 3 단계, 이미지 1/2 1986-1993 Volvo 240 Front Brake Rotors Replacement: 3 단계, 이미지 2/2
    • Lift the brake caliper off the rotor and set it aside.
    • Place the caliper on some type of support so that you do not put too much strain on the brake hose.
  4. 1986-1993 Volvo 240 Front Brake Rotors Replacement, Front Brake Rotors: 4 단계, 이미지 1/1
    • Pull the brake rotor straight off the wheel lugs to remove it.
  5. 1986-1993 Volvo 240 Front Brake Rotors Replacement: 5 단계, 이미지 1/1
    • Place the new brake rotor over the wheel lugs.
    • Most new brake rotors can be installed without any additional work, but if your rotors are out of round they will need to be turned.
결론
To reassemble your device, follow these instructions in reverse order starting at Step 3.
다른 3명이 해당 안내서를 완성하였습니다.
Brett Hartt
회원 가입일: 04/12/10
128,242 평판
안내서 143개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,077개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 17
전체 시간: 6,558
