주요 콘텐츠로 건너뛰기
1986-1993 Volvo 240 Spark Plug Wires Replacement
필요한 것
  1. 1986-1993 Volvo 240 Spark Plug Wires Replacement, Spark Plug Wires: 1 단계, 이미지 1/1
    • To avoid any confusion between which wire goes to which spark plug, replace spark plug wires one at a time. You may want to mark either the old or new wires to remind yourself which ones you've changed.
    • Disconnect the spark plug wire from the distributor cap by pulling it straight up.
  2. 1986-1993 Volvo 240 Spark Plug Wires Replacement: 2 단계, 이미지 1/2 1986-1993 Volvo 240 Spark Plug Wires Replacement: 2 단계, 이미지 2/2
    • Gently twist the spark plug boot back and forth and pull up to remove it from the spark plug.
    • When installing your new spark plug wires, it's a good idea to apply dielectric grease to the spark plug boots to prevent the electrical connections from being damaged by water or debris.
결론
Install your new spark plug wires in the same manner that you removed the old ones.
다른 2명이 해당 안내서를 완성하였습니다.
David Hodson
회원 가입일: 04/13/10
150,882 평판
안내서 127개 작성하였습니다
댓글 2개
Doing this today. Thanks for the clear, reassuring steps to get it done :)
jeconnol - 답글
These directions were great! Thank you. I got the wires on in about 40 minutes. Oh, and I’m a girlie girl. :)
Nancy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 4,060
