소개
- Look closely at the handlebar cover
Clear all the stuff from your dashboard.
Then pull the radio out of the shaft.
With a jerk you lift the cover of the console (dashboard) from the windshield ago.
Loosen the 4 screws on the left and right of the instrument panel. IMAGE
Pull the switches in the instrument panel off the plugs and set aside
The hazard warning lights have a blue and a brown single cable in addition to the plug
When lifting the instruments (on the side of the speed display), pull the white plug.
On the back of the speedometer, remove the plugged-in speedometer cable from the white plug. [Br] Now remove the instrument panel
Repeat the steps in order to reassemble your device.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
irlanda님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
