주요 콘텐츠로 건너뛰기
1990-1993 Honda Accord EX Engine Air Filter Replacement
필요한 것
  1. 1990-1993 Honda Accord EX Engine Air Filter Replacement, Engine Air Filter: 1 단계, 이미지 1/3 1990-1993 Honda Accord EX Engine Air Filter Replacement, Engine Air Filter: 1 단계, 이미지 2/3 1990-1993 Honda Accord EX Engine Air Filter Replacement, Engine Air Filter: 1 단계, 이미지 3/3
    • Flip the switch underneath the steering wheel to open the hood.
  2. 1990-1993 Honda Accord EX Engine Air Filter Replacement: 2 단계, 이미지 1/3 1990-1993 Honda Accord EX Engine Air Filter Replacement: 2 단계, 이미지 2/3 1990-1993 Honda Accord EX Engine Air Filter Replacement: 2 단계, 이미지 3/3
    • Open the hood, and keep it in place using the prop rod.
  3. 1990-1993 Honda Accord EX Engine Air Filter Replacement: 3 단계, 이미지 1/2 1990-1993 Honda Accord EX Engine Air Filter Replacement: 3 단계, 이미지 2/2
    • Remove the four 1.3 cm Phillips screws from the cover of the case.
  4. 1990-1993 Honda Accord EX Engine Air Filter Replacement: 4 단계, 이미지 1/2 1990-1993 Honda Accord EX Engine Air Filter Replacement: 4 단계, 이미지 2/2
    • Remove the cover of the casing.
  5. 1990-1993 Honda Accord EX Engine Air Filter Replacement: 5 단계, 이미지 1/3 1990-1993 Honda Accord EX Engine Air Filter Replacement: 5 단계, 이미지 2/3 1990-1993 Honda Accord EX Engine Air Filter Replacement: 5 단계, 이미지 3/3
    • Remove the old air filter and replace it with a brand-new one.
    • Place the new air filter in the same position as the old one otherwise, you will not be able to screw the cover back on.
  6. 1990-1993 Honda Accord EX Engine Air Filter Replacement: 6 단계, 이미지 1/2 1990-1993 Honda Accord EX Engine Air Filter Replacement: 6 단계, 이미지 2/2
    • Place the cover back on the casing and screw it back in place.
    • Do not tighten the screws too hard or you risk the chance of breaking the screws.
결론
Oscar Sanchez
회원 가입일: 10/24/23
133 평판
안내서 1개 작성함
CSU Los Angeles, Team 8-9, Ribeiro Fall 2023 CSU Los Angeles, Team 8-9, Ribeiro Fall 2023 회원
CSULA-RIBEIRO-F23S8G9
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 13
전체 시간: 100
