주요 콘텐츠로 건너뛰기
1991-1996 Chevrolet Caprice Battery Replacement
필요한 것
  1. 1991-1996 Chevrolet Caprice Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Find the hood lever, this is normally under the dash, to the left of the steering wheel.
  2. 1991-1996 Chevrolet Caprice Battery Replacement: 2 단계, 이미지 1/1
    • Pull the lever and the hood will pop up.
  3. 1991-1996 Chevrolet Caprice Battery Replacement: 3 단계, 이미지 1/1
    • Go to the front of the car and push the lever up to unlatch the hood, you may need to feel around for a minute to find this.
  4. 1991-1996 Chevrolet Caprice Battery Replacement: 4 단계, 이미지 1/1
    • Find the battery, this is normally to the left front of the engine.
  5. 1991-1996 Chevrolet Caprice Battery Replacement: 5 단계, 이미지 1/1
    • Once you have found the battery. It is time to unscrew the bolts holding in the wires.
    • The red circle is positive and the black circle is the negative.
    • If you see battery acid on the terminal bolts remove this be using baking soda mixed with water and a tooth brush.
  6. 1991-1996 Chevrolet Caprice Battery Replacement: 6 단계, 이미지 1/1
    • With your 8mm wrench remove the negative terminal bolt.
    • Make sure the negative and positive terminals do not touch!
  7. 1991-1996 Chevrolet Caprice Battery Replacement: 7 단계, 이미지 1/1
    • Now with your 15mm wrench remove the positive terminal bolt, the same way you removed the negative terminal bolt.
  8. 1991-1996 Chevrolet Caprice Battery Replacement: 8 단계, 이미지 1/2 1991-1996 Chevrolet Caprice Battery Replacement: 8 단계, 이미지 2/2
    • With your 13mm socket, remove the bolt that holds the block, that holds the battery in. This bolt will not come out completely. Once you feel slack in the bolt you may remove the whole block.
    • Make sure you do not touch the positive and negative terminals, you might get shocked!
  9. 1991-1996 Chevrolet Caprice Battery Replacement: 9 단계, 이미지 1/1
    • Now lift out the battery using the handle shown.
    • To recycle your old battery take it back to the store where you bought the new battery.
  10. 1991-1996 Chevrolet Caprice Battery Replacement: 10 단계, 이미지 1/1
    • To install the new battery follow these steps in reverse order from step 8-5.
    • When putting the battery bolts back in, make sure you put the negative bolt in first and then the positive bolt in second.
결론
Also find the right battery for this type of car.
다른 6명이 해당 안내서를 완성하였습니다.
Vaughn Higginbotham
회원 가입일: 04/17/14
1,221 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 17
30일 전: 38
전체 시간: 6,278
