주요 콘텐츠로 건너뛰기
1991-1996 Toyota Camry Oil and Oil Filter Replacement
필요한 것
동영상 개요
  1. 1991-1996 Toyota Camry Oil and Oil Filter Replacement, Oil and Oil Filter: 1 단계, 이미지 1/1
    • Locate the oil filter under the exhaust manifold in the front of the vehicle
    • source.
  2. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 2 단계, 이미지 1/1
    • Place the Lisle 63600 Oil Filter Tool over the filter, use an extension on the ratchet to reach around the hot manifold, and loosen the filter
    • source
    • Be careful not to burn yourself on the hot manifold.
  3. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 3 단계, 이미지 1/1
    • Unscrew the oil filter and let it drain into the oil drain pan
    • source
    • Make sure the pan is aligned to catch oil from both the filter and drain plug.
  4. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 4 단계, 이미지 1/1
    • Carefully remove the old oil filter
    • source.
  5. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 5 단계, 이미지 1/3 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 5 단계, 이미지 2/3 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 5 단계, 이미지 3/3
    • Clean the mating surface where the new filter will be installed
    • Ensure there are no old seals or debris that could affect the new filter's seal
    • source.
  6. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 6 단계, 이미지 1/1
    • Install the new oil filter by hand tightening it
    • source.
  7. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 7 단계, 이미지 1/2 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 7 단계, 이미지 2/2
    • Move to the oil drain plug location and remove it using the 14mm socket and ratchet
    • source
    • Let the oil drain into the pan
    • source.
  8. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 8 단계, 이미지 1/1
    • Replace the old gasket on the drain plug with a new one, if necessary
    • source.
  9. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 9 단계, 이미지 1/2 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 9 단계, 이미지 2/2
    • Tighten the drain plug using the 14mm socket
    • source
    • Clean up any excess oil
    • source.
  10. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 10 단계, 이미지 1/3 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 10 단계, 이미지 2/3 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 10 단계, 이미지 3/3
    • Refill the engine with 5W-30 oil using a funnel
    • source
    • This engine should take about five quarts
    • source
    • Be careful when filling the oil, as there is a plate just under the fill opening that can cause spills
    • source
    • Tilt the funnel to ensure the oil goes into the engine
    • source.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
eCuration
회원 가입일: 05/19/17
378,307 평판
안내서 236개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,895개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 26
전체 시간: 9,904
