주요 콘텐츠로 건너뛰기
1992-1999 BMW 3 Series Oil Replacement
필요한 것
  1. 1992-1999 BMW 3 Series Oil Replacement, Oil: 1 단계, 이미지 1/2 1992-1999 BMW 3 Series Oil Replacement, Oil: 1 단계, 이미지 2/2
    • Open the hood of the car by first pulling the black lever located in the drivers side footwell.
    • Lift upward on the latch located underneath the hood to release the hood.
  2. 1992-1999 BMW 3 Series Oil Replacement: 2 단계, 이미지 1/2 1992-1999 BMW 3 Series Oil Replacement: 2 단계, 이미지 2/2
    • Jack up the car using the jack points located underneath the sides of the car.
    • Tip: it is advised to use Jackstands to support the car in case of jack failure.
    • Tip 2: It may only be necessary to lift one corner of the car in order to change the oil. The right front jack point seems to be the best for this.
  3. 1992-1999 BMW 3 Series Oil Replacement: 3 단계, 이미지 1/3 1992-1999 BMW 3 Series Oil Replacement: 3 단계, 이미지 2/3 1992-1999 BMW 3 Series Oil Replacement: 3 단계, 이미지 3/3
    • Place the oil pan underneath the plug
    • Using a 17mm socket, remove the drain plug.
    • Allow the oil to fully drain into the oil pan.
    • Reinstall the drain plug after the the oil stops dripping from the drain hole.
  4. 1992-1999 BMW 3 Series Oil Replacement: 4 단계, 이미지 1/3 1992-1999 BMW 3 Series Oil Replacement: 4 단계, 이미지 2/3 1992-1999 BMW 3 Series Oil Replacement: 4 단계, 이미지 3/3
    • Remove the Oil Filter Housing bolt using a 13mm socket. Lift upwards on the oil filter housing cap to remove it.
    • Lift the old oil filter straight up to remove it. Place a towel underneath it as you lift to catch any dripping oil.
    • While the oil filter is out, inspect the gaskets on the oil filter housing cap and bolt. Replace if necessary.
    • Install the new oil filter and reinstall the oil filter housing.
  5. 1992-1999 BMW 3 Series Oil Replacement: 5 단계, 이미지 1/3 1992-1999 BMW 3 Series Oil Replacement: 5 단계, 이미지 2/3 1992-1999 BMW 3 Series Oil Replacement: 5 단계, 이미지 3/3
    • Remove the oil filler cap and slowly pour seven quarts of oil into the engine.
    • Pull the Dipstick out and inspect the oil level. The oil level should be between the two marked lines.
결론
Place the oil cap back on, close the hood, and lower the car. You have now successfully changed the oil on your BMW E36.
다른 2명이 해당 안내서를 완성하였습니다.
Geoff Wacker
회원 가입일: 09/30/13
90,075 평판
안내서 89개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 42
30일 전: 202
전체 시간: 5,294
