주요 콘텐츠로 건너뛰기
1994-2004 Ford Mustang Battery Replacement
필요한 것
  1. 1994-2004 Ford Mustang Battery Replacement, Battery: 1 단계, 이미지 1/2 1994-2004 Ford Mustang Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Pull the piece marked "HOOD" out in the direction of the arrow to release the hood lock at the front of the vehicle.
  2. 1994-2004 Ford Mustang Battery Replacement: 2 단계, 이미지 1/3 1994-2004 Ford Mustang Battery Replacement: 2 단계, 이미지 2/3 1994-2004 Ford Mustang Battery Replacement: 2 단계, 이미지 3/3
    • Pull the yellow hood latch left to unlock the latch holding the hood of the car in place.
    • Lift the hood up to reveal the battery.
  3. 1994-2004 Ford Mustang Battery Replacement: 3 단계, 이미지 1/1
    • Disconnect the negative power connection (black) with a 3/8" ratchet and a 1/2" socket.
  4. 1994-2004 Ford Mustang Battery Replacement: 4 단계, 이미지 1/1
    • Disconnect the positive power connection (red) with a 3/8" ratchet and a 1/2" socket.
  5. 1994-2004 Ford Mustang Battery Replacement: 5 단계, 이미지 1/2 1994-2004 Ford Mustang Battery Replacement: 5 단계, 이미지 2/2
    • Pull the battery up and remove it from the vehicle.
    • Place the new battery in the same battery holder area that you just removed the old battery from.
결론
Jacob Locke
회원 가입일: 01/08/21
156 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 15
30일 전: 56
전체 시간: 1,653
