소개
This guide shows how to remove the interior door panels to access multiple components. The method is almost exactly the same for the passenger's side, except there is no connector for the side-view mirror controls.
필요한 것
Remove the plastic Phillips screw towards the front of the door panel.
Use a flathead screwdriver to remove the plastic clip that holds the screw.
Push down on the small tab and pull the connector directly away from its socket to disconnect the power lock switch.
Use the same method described above to remove the connector for the tweeter.
Press the tab on the bottom of the larger green connector to disconnect the side-view mirror controls.
다른 5명이 해당 안내서를 완성하였습니다.
