주요 콘텐츠로 건너뛰기
1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement
필요한 것
동영상 개요
  1. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement, 3.4L Timing Belt/ Water Pump: 1 단계, 이미지 1/1
  2. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 2 단계, 이미지 1/1
  3. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 3 단계, 이미지 1/1
  4. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 4 단계, 이미지 1/3 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 4 단계, 이미지 2/3 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 4 단계, 이미지 3/3
  5. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 5 단계, 이미지 1/1
    • Loosen up the idler pulley by getting underneath the car and removing the 12mm bolt at the bottom of the idler pulley .
  6. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 6 단계, 이미지 1/1
  7. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 7 단계, 이미지 1/1
  8. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 8 단계, 이미지 1/1
  9. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 9 단계, 이미지 1/1
  10. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 10 단계, 이미지 1/1
    • Remove the nut that holds the pulley in place, which should be torqued down to 250 lbs .
  11. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 11 단계, 이미지 1/1
    • Using a 19mm wrench and a pipe, remove the nut and then remove the pulley .
  12. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 12 단계, 이미지 1/1
  13. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 13 단계, 이미지 1/1
  14. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 14 단계, 이미지 1/1
  15. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 15 단계, 이미지 1/1
  16. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 16 단계, 이미지 1/1
    • Line up the notches on the camshafts to set the timing before removing the belt .
  17. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 17 단계, 이미지 1/1
  18. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 18 단계, 이미지 1/1
    • Line up the camshafts by rotating the big pulley until the notches line up .
  19. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 19 단계, 이미지 1/1
  20. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 20 단계, 이미지 1/1
  21. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: 21 단계, 이미지 1/1
결론
Additional Information
- When lining up the camshafts, make sure to align the notches with the backplate, as well as the small arrow and dot on the bottom
- It is important to get all the old gasket off to prevent leaks.
다른 4명이 해당 안내서를 완성하였습니다.
eCuration
회원 가입일: 05/19/17
376,693 평판
안내서 234개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 한 개
Thank you so much for the video! As for ordering the parts for this repair i will go ahead and save a lot of trouble for those of you who may not already know when asked about weather you need the water pump that comes WITH ot WITHOUT the ENGINE oil cooler stem, I own a 1999 Toyota Tacoma Four-Wheel Drive V6 3.4L 5-Speed Manual Transmission
NikkiAutumn - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 76
30일 전: 405
전체 시간: 61,045
