주요 콘텐츠로 건너뛰기
1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement
필요한 것
  1. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement, Front and rear wiper blades: 1 단계, 이미지 1/1
    • Get your wipers in the service position by lifting the wiper arm up until it stands on its own.
  2. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 2 단계, 이미지 1/3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 2 단계, 이미지 2/3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 2 단계, 이미지 3/3
    • Unlatch the cover on the old wiper blade from the arm.
  3. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 3 단계, 이미지 1/2 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 3 단계, 이미지 2/2
    • Firmly grasp the wiper blade and pull the wiper blade towards the car.
    • Turn the wiper blade 90 degrees so that it is perpendicular to the wiper arm.
    • Note: Use a 'J' motion to unhook the wiper blade from the wiper arm.
    • Pull the wiper blade away from the wiper arm.
  4. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 4 단계, 이미지 1/2 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 4 단계, 이미지 2/2
    • Rest the wiper arm on a towel.
    • Putting the wiper arm down removes the risk of it falling over and placing the wiper arm on a towel removes the risk of scratching the windshield.
  5. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 5 단계, 이미지 1/2 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 5 단계, 이미지 2/2
    • Prepare the new wiper blade.
    • Note: There are several different types of adapters. The 4runner uses a J-hook adapter.
    • Refer to the instruction manual from the new wiper blade to ensure you have the correct adaptor attached.
  6. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 6 단계, 이미지 1/3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 6 단계, 이미지 2/3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 6 단계, 이미지 3/3
    • Lift the wiper arm from the down position back into the service position.
    • Insert the wiper arm perpendicular to the wiper blade in the hole.
    • Insert the J-hook into the wiper blade.
    • Note: When inserting, make a 'J' type motion.
    • Turn the wiper blade so that it is parallel to the wiper arm.
    • Firmly grasp the wiper blade and shift it away from the wiper arm until you hear an audible click that confirms that it is secured.
  7. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 7 단계, 이미지 1/1
    • Close the latch on the new wiper blade.
  8. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 8 단계, 이미지 1/2 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 8 단계, 이미지 2/2
    • Remove the towel from the windshield and lower the wiper arm back down.
  9. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 9 단계, 이미지 1/3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 9 단계, 이미지 2/3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 9 단계, 이미지 3/3
    • Repeat the previous eight steps for the second wiper blade.
  10. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 10 단계, 이미지 1/3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 10 단계, 이미지 2/3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 10 단계, 이미지 3/3
    • Remove the two Phillips screws from the rear wiper assembly.
    • The screws will be reused for this part.
    • Place a towel underneath the wiper arm.
  11. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 11 단계, 이미지 1/3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 11 단계, 이미지 2/3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 11 단계, 이미지 3/3
    • Place the old wiper fixture onto the new wiper blade.
  12. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 12 단계, 이미지 1/2 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 12 단계, 이미지 2/2
    • Screw in the rear wiper assembly hand-tight.
    • Do not fully tighten the screws.
  13. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 13 단계, 이미지 1/1
    • Align the rear wiper assembly and tighten the screws once it is aligned.
결론
Replacing your wiper blades following the steps outlined in this guide is a simple yet crucial maintenance task to ensure optimal performance and safety on the road. By regularly inspecting and replacing worn-out blades, you can maintain clear visibility and confidence in various weather conditions, ultimately enhancing your driving safety.
다른 한 분이 해당 안내서를 완성하였습니다.
OptimusPrime
회원 가입일: 04/15/24
217 평판
안내서 1개 작성함
UC Davis, Team 2-7, Morris Spring 2024 UC Davis, Team 2-7, Morris Spring 2024 회원
UCD-MORRIS-S24S2G7
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 26
전체 시간: 107
