주요 콘텐츠로 건너뛰기
1995-2002 Toyota 4Runner Interior Ceiling Light Replacement
필요한 것
  1. 1995-2002 Toyota 4Runner Interior Ceiling Light Replacement, Interior Ceiling Light: 1 단계, 이미지 1/1
    • Remove the key from the ignition and turn off the vehicle.
  2. 1995-2002 Toyota 4Runner Interior Ceiling Light Replacement: 2 단계, 이미지 1/2 1995-2002 Toyota 4Runner Interior Ceiling Light Replacement: 2 단계, 이미지 2/2
    • Turn the interior ceiling light off.
  3. 1995-2002 Toyota 4Runner Interior Ceiling Light Replacement: 3 단계, 이미지 1/3 1995-2002 Toyota 4Runner Interior Ceiling Light Replacement: 3 단계, 이미지 2/3 1995-2002 Toyota 4Runner Interior Ceiling Light Replacement: 3 단계, 이미지 3/3
    • Using a flathead screwdriver, place it in the gap and remove the light cover.
  4. 1995-2002 Toyota 4Runner Interior Ceiling Light Replacement: 4 단계, 이미지 1/2 1995-2002 Toyota 4Runner Interior Ceiling Light Replacement: 4 단계, 이미지 2/2
    • Unplug the LED interior ceiling light and remove it from the vehicle.
  5. 1995-2002 Toyota 4Runner Interior Ceiling Light Replacement: 5 단계, 이미지 1/2 1995-2002 Toyota 4Runner Interior Ceiling Light Replacement: 5 단계, 이미지 2/2
    • Turn on the interior light to test the LED replacement.
    • Remember to start your vehicle and make sure your vehicle is running before testing the interior light.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Maunel Castro
회원 가입일: 10/23/20
169 평판
안내서 1개 작성함
CSU Los Angeles, Team S12-G20, Harris Spring 2020 CSU Los Angeles, Team S12-G20, Harris Spring 2020 회원
CSULA-HARRIS-S20S12G20
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 26
전체 시간: 836
