주요 콘텐츠로 건너뛰기
1996-1998 Acura TL Stereo Head Unit Replacement
필요한 것
  1. 1996-1998 Acura TL Stereo Head Unit Replacement, Center Dash: 1 단계, 이미지 1/1
    • Using a panel tool or long flat head screwdriver, pry the wood grain trim off and release the clips. Be careful on the thin sections below the head unit as to not snap the trim.
  2. 1996-1998 Acura TL Stereo Head Unit Replacement: 2 단계, 이미지 1/1
    • Detach the wiring harness from the back of the air conditioning control unit by pushing down on the top middle tab and pulling apart using a screwdriver for leverage if necessary.
  3. 1996-1998 Acura TL Stereo Head Unit Replacement, Stereo Head Unit: 3 단계, 이미지 1/1
    • Unscrew the four screws from the sides of the deck, circled here.
  4. 1996-1998 Acura TL Stereo Head Unit Replacement: 4 단계, 이미지 1/1
    • Pull the head unit straight out gently until the two wire harnesses are exposed.
  5. 1996-1998 Acura TL Stereo Head Unit Replacement: 5 단계, 이미지 1/1
    • Push down on the tabs and remove the wiring from their blue and white harnesses.
    • These two are harder to remove than the others so do not be afraid to use force, or a flathead screw driver for leverage to pop them out.
    • As long as you are pushing the tab and force it out at a straight angle neither the plastic nor the wiring will be damaged.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Brayden
회원 가입일: 10/05/12
16 평판
안내서 5개 작성하였습니다
Cal Poly, Team 18-42, Regan Fall 2012 Cal Poly, Team 18-42, Regan Fall 2012 회원
CPSU-REGAN-F12S18G42
4 회원들
안내서 5개 작성하였습니다
댓글 2개
Awesome! I got an Acura TL 1998
PROJECT zeroto100 - 답글
Thank you for the guid. Can you please make another about how you put aux into this Stereo Head Unit?
Сергей Твердохлеб - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 16
전체 시간: 4,219
