주요 콘텐츠로 건너뛰기
1996-1998 Subaru Legacy Oil Change
필요한 것
    • Pull the hood latch to release the front hood.
    • Go around to the front of the car and trigger the lever to raise the hood.
    • Lift the hood prop and insert the end into the hood.
    • Locate the oil drain plug underneath the vehicle.
    • Put down some newspaper or cardboard to catch any spills or splashes
    • Slide the oil pan under the drain plug.
    • Take your 17mm socket and loosen the drain plug.
    • Once loose enough, remove the plug by hand.
    • The oil may be hot, so wear latex gloves when removing the plug.
    • Let the oil drain out until its just a drip.
    • Clean off the plug with a paper towel or rag.
    • Re-screw drain plug back into the oil pan.
    • Make sure it's not to tight or loose - check the owners manual for torque specifications.
    • Locate the Oil Filter on the underside of the car.
    • Remove the oil filter and let the oil drain out.
    • Re-add the new, fresh oil filter.
    • Add 4.8 Quarts of new oil.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tim Asp
회원 가입일: 01/24/11
3,905 평판
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 32
전체 시간: 33,135
