이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Pull the hood latch to release the front hood.
Go around to the front of the car and trigger the lever to raise the hood.
Lift the hood prop and insert the end into the hood.
Locate the oil drain plug underneath the vehicle.
Slide the oil pan under the drain plug.
Take your 17mm socket and loosen the drain plug.
Once loose enough, remove the plug by hand.
Let the oil drain out until its just a drip.
Clean off the plug with a paper towel or rag.
Re-screw drain plug back into the oil pan.
Make sure it's not to tight or loose - check the owners manual for torque specifications.
Locate the Oil Filter on the underside of the car.
Remove the oil filter and let the oil drain out.
Re-add the new, fresh oil filter.
다른 한 분이 해당 안내서를 완성하였습니다.
