주요 콘텐츠로 건너뛰기
1997-2006 Jeep Wrangler (TJ) Headlight Replacement
필요한 것
  1. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement, Headlight: 1 단계, 이미지 1/1
    • Unclasp and prop up the hood.
  2. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: 2 단계, 이미지 1/1
    • Remove the three 15.9 mm screws around the external ring casing with a Phillips #0 screwdriver.
  3. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: 3 단계, 이미지 1/1
    • Pull out the external ring casing.
  4. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: 4 단계, 이미지 1/2 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: 4 단계, 이미지 2/2
    • Remove the four screws securing the internal ring casing with a T15 Torx screwdriver.
  5. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: 5 단계, 이미지 1/1
    • Disconnect the headlight assembly from the vehicle by pulling the connector directly out of the back port.
  6. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: 6 단계, 이미지 1/1
    • Realign the internal bracket to match the screw holes.
  7. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: 7 단계, 이미지 1/1
    • Reinstall the four screws securing the internal ring casing with a T15 Torx screwdriver.
  8. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: 8 단계, 이미지 1/1
    • Realign the external bracket to match the screw holes.
  9. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: 9 단계, 이미지 1/1
    • Replace the three 15.9 mm screws using a Phillips #0 screwdriver.
  10. 1997-2006 Jeep Wrangler (TJ) Headlight Replacement: 10 단계, 이미지 1/1
    • Close and clasp the hood back to its original position.
결론
Enjoy your bright new headlight(s)!
다른 한 분이 해당 안내서를 완성하였습니다.
Troy Taylor
회원 가입일: 02/28/22
199 평판
안내서 1개 작성함
University of Memphis, Team 2-10, Willis Spring 2022 University of Memphis, Team 2-10, Willis Spring 2022 회원
UM-WILLIS-S22S2G10
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 16
30일 전: 76
전체 시간: 3,438
