주요 콘텐츠로 건너뛰기
1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement
필요한 것
  1. 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement, Instrument Cluster Light Bulbs: 1 단계, 이미지 1/1
    • First a look at the original lights in the dash.
  2. 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: 2 단계, 이미지 1/3 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: 2 단계, 이미지 2/3 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: 2 단계, 이미지 3/3
    • Remove the three screws along the top of the dash cluster.
    • There is a cover to gain access to the top two of four screws that hold the cluster in.
  3. 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: 3 단계, 이미지 1/3 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: 3 단계, 이미지 2/3 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: 3 단계, 이미지 3/3
    • Remove the two screws that hold the second part of the dash cluster, then remove the dash cluster.
  4. 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: 4 단계, 이미지 1/3 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: 4 단계, 이미지 2/3 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: 4 단계, 이미지 3/3
    • Now that all four screws holding the dash on are visible, remove them to allow the dash to come off.
  5. 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: 5 단계, 이미지 1/3 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: 5 단계, 이미지 2/3 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: 5 단계, 이미지 3/3
    • Assemble the new lights by pushing the butt end of the bulb down into the body until seated fully.
    • The bulbs are polarity sensitive so pay attention to the direction that you put them in.
  6. 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: 6 단계, 이미지 1/3 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: 6 단계, 이미지 2/3 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: 6 단계, 이미지 3/3
    • Remove the old light bulbs from the dash and replace them with the new ones. To do so simply twist the body of the light and it will pop right out. To install the new bulbs do the opposite. Push the body of the bulb flush with the mounting surface on the dash and then twist to hold it tight.
  7. 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: 7 단계, 이미지 1/1
    • The final step is the reassembly. This is very easy as you simply repeat the steps taken to remove the dash but in opposite order. If upon reassembly you find some of the lights not working simply remove the bulb in question and switch the direction of the bulb in the body. That will fix the problem. As you can see the result is well worth it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mason
회원 가입일: 10/12/20
187 평판
안내서 1개 작성함
University of Memphis, Team S2-G10, Willis Fall 2020 University of Memphis, Team S2-G10, Willis Fall 2020 회원
UM-WILLIS-F20S2G10
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 27
30일 전: 115
전체 시간: 10,225
