주요 콘텐츠로 건너뛰기
1997-2003 BMW 5 Series BMW E38 E39 X5 X3 Z4 E46 MP3 Player Replacement
필요한 것
동영상 개요
A video about installing MP3 Player in BMW E39 http://www.youtube.com/watch?v=_6wg3qTvU....
  1. 1997-2003 BMW 5 Series BMW E38 E39 X5 X3 Z4 E46 MP3 Player Replacement, BMW E38 E39 X5 X3 Z4 E46 MP3 Player: 1 단계, 이미지 1개 중 1개
    • Remove screws holding the CD changer in place (if equipped)
    • Disconnect BMW CD changer 3 pin power plug and 6 pin audio plug from CD changer.
    • Connect MP3 Player to original CD changer connectors
  2. 1997-2003 BMW 5 Series BMW E38 E39 X5 X3 Z4 E46 MP3 Player Replacement: 2 단계, 이미지 3개 중 1개 1997-2003 BMW 5 Series BMW E38 E39 X5 X3 Z4 E46 MP3 Player Replacement: 2 단계, 이미지 3개 중 2개 1997-2003 BMW 5 Series BMW E38 E39 X5 X3 Z4 E46 MP3 Player Replacement: 2 단계, 이미지 3개 중 3개
    • If using the 3 and 6 Pin connector version MP3 player, you will need to connect the unit to a switched power source in order to retain its last song played memory function.
    • A good connection for BMWs built after Jan, 2000 production is the SES wiring plug, which is no longer used in cars that are equipped with the BMW Bluetooth system
    • Switched power is located on pin 24 Violet/White (or Violet/Red see image.
    • If you are also installing the DSP adapter module with your MP3 player you can connect the DSP module adapter to this pin in addition to using pin 14 brown/black for ground.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Martin Bishop
회원 가입일: 01/26/12
4,427 평판
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 35
전체 시간: 14,123
