주요 콘텐츠로 건너뛰기
1997-2003 BMW 5 Series Key Battery Replacement
필요한 것
    • Try and see first if the key was simply "forgotten" by the car by reprogramming it:
    • Open the car with the second key, get in and close the door, but don't shut it all the way.
    • Put the key that needs to be reprogrammed into the starter and turn it to the "Radio" position. Leave it in this position for a few seconds and then pull it back out. The system is now ready for reprograming.
    • Press and hold-down the "open" button and then press the "close" button three times. Now, let go of the "open" button. The locking system should respond by locking and unlocking all doors, with a "click-clack"
    • Important: The second key must be reprogrammed within 10 seconds, otherwise it will no longer work. For this it must not be put back into the starter.
    • If this worked, you can stop - otherwise, follow the next steps.
  1. 1997-2003 BMW 5 Series Key Battery Replacement: 2 단계, 이미지 1/3 1997-2003 BMW 5 Series Key Battery Replacement: 2 단계, 이미지 2/3 1997-2003 BMW 5 Series Key Battery Replacement: 2 단계, 이미지 3/3
    • The two halves of the casing are glued together. Separate the seam between the upper and lower casing with a sharp utility knife.
    • The process is tricky and time-consuming, cutting again and again around the key. Work slowly and patiently.
    • Don't cut deeper than 3 millimeters, so you don't come into contact with the circuit board.
  2. 1997-2003 BMW 5 Series Key Battery Replacement: 3 단계, 이미지 1/3 1997-2003 BMW 5 Series Key Battery Replacement: 3 단계, 이미지 2/3 1997-2003 BMW 5 Series Key Battery Replacement: 3 단계, 이미지 3/3
    • When the seam is open wide enough, slide a pick inside.
    • Then separate the casings with an appropriate tool.
  3. 1997-2003 BMW 5 Series Key Battery Replacement: 4 단계, 이미지 1/2 1997-2003 BMW 5 Series Key Battery Replacement: 4 단계, 이미지 2/2
    • Here is what the inside of the casing looks like. The circuit board has already been removed.
  4. 1997-2003 BMW 5 Series Key Battery Replacement: 5 단계, 이미지 1/3 1997-2003 BMW 5 Series Key Battery Replacement: 5 단계, 이미지 2/3 1997-2003 BMW 5 Series Key Battery Replacement: 5 단계, 이미지 3/3
    • The circuit board.
    • The battery type is VL2020. Pay attention to the welded flag connectors, which are in right angles of each other.
  5. 1997-2003 BMW 5 Series Key Battery Replacement: 6 단계, 이미지 1/3 1997-2003 BMW 5 Series Key Battery Replacement: 6 단계, 이미지 2/3 1997-2003 BMW 5 Series Key Battery Replacement: 6 단계, 이미지 3/3
    • Desolder the battery from the solder joints marked in red.
    • Use a desoldering pump or desoldering wick.
    • Lift the battery out carefully.
  6. 1997-2003 BMW 5 Series Key Battery Replacement: 7 단계, 이미지 1/2 1997-2003 BMW 5 Series Key Battery Replacement: 7 단계, 이미지 2/2
    • If there isn't an insulation layer on the back, then place a piece of insulation tape there.
  7. 1997-2003 BMW 5 Series Key Battery Replacement: 8 단계, 이미지 1/1
    • Put everything back together. Do not glue the casings yet. Instead, hold them together with a rubber band.
    • Check whether the micro switches are clicking. If not, move the circuit board back into the right position again.
    • Normally, the key - as mentioned in step 1 - will have to be reprogrammed. And don’t forget about the second key.
    • When everything is working, you can glue the two halves back together with the appropriate glue – for instance Super Glue – and carefully sand off any excess glue.
결론
Complete the steps in reverse order to reassemble your device.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
B. ihle님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
VauWeh
회원 가입일: 10/19/15
186,089 평판
안내서 230개 작성하였습니다
Repair is War on Entropy Repair is War on Entropy 회원
Community
21 회원들
안내서 981개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 78
30일 전: 366
전체 시간: 4,331
